Old 01-19-2014, 01:21 PM   #1
ollucky
Default Re: Help car drops 700 rpm when going from neutral to first
Originally Posted by 1320racer View Post
with his big cam and tight converter, i would bet he will need to drill the throttle blades if not already done.
Throttle blades are drilled
ollucky is offline   Reply With Quote
Old 01-19-2014, 01:24 PM   #2
SSDart
All four? How big are the holes? If the holes are too big they can create issues also
SSDart is offline   Reply With Quote
Old 01-19-2014, 01:40 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
get the carb off yet?
Old 01-19-2014, 02:04 PM   #4
ollucky
Please Call Me 210 533 8058 Raul
Old 01-19-2014, 03:06 PM   #5
ollucky
.165 bore have use this carburetor for years and have never had this problem.
Old 01-19-2014, 03:17 PM   #6
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
There is the key. What has been done/changed since the last time it ran properly? You stated this is a new combination...did you by any chance add/change any timing related or ignition components?
Rich Taylor
I/SA - 321
Old 01-19-2014, 03:52 PM   #7
1320racer
1320racer's Avatar
Raul, making any headway?
Old 01-19-2014, 07:07 PM   #8
ollucky
1320 Racer ... Please send me your number and I'll call you. thanks
Raul
Old 01-19-2014, 07:49 PM   #9
ollucky
Just engine combo long block? Went from a 355 to a 406. Same Heads Intake and Carb for the last 15 years.
Old 01-19-2014, 08:08 PM   #10
HandOverFist
My point was carb's don't just go bad/quit working overnight. Unless it has sit idle for a very long time with old fuel I would tend to look elsewhere first. Someone suggested earlier trying another carb for effect...way less time consuming and a quick way to eliminate one potential area.
Rich Taylor
I/SA - 321
