Old 12-25-2013, 10:51 PM   #11
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Default Re: 60' times
In this case the 60' time is actually the time to go 60'+the car's wheelbase. You car then back cipher what it would have been in the front wheels tripped the 60' beams.
Old 12-25-2013, 11:08 PM   #12
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Let's say the car 60' on the back wheels @ 1.40...would it mean the car's actual 60' would have been around 1.29 if the front wheels had tripped the beam? Hard to figure a formula to arrive at it.
Rich Taylor
I/SA - 321
Old 12-25-2013, 11:36 PM   #13
HP HUNTER
Liked 373 Times in 129 Posts
This was the absolute fastest pass made by this car, and the fastest 330
1.403
3.74
5.86 115.7
9.29 142.3
This was the fastest 60 foot ever by the same car with the lights tripped by the front tires
1.28
I feel this is pretty accurate, a 67 Chevelle that trips on the rear tires runs about 12 hundreths quicker than the 60 foot clocks indicate.
My 68 Chevelle very consistently goes 1.395 on the rear tires, 3.73 330 although a shorter wheel base than the 67.
http://www.trracecars.com/2foot.jpg
http://www.trracecars.com/3foot.jpg
http://www.trracecars.com/4foot.jpg
Old 12-25-2013, 11:59 PM   #14
HandOverFist
I'll be damned...my guesswork/math was pretty darn close lol.
Rich Taylor
I/SA - 321
Old 12-26-2013, 09:18 AM   #15
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Could stage w/ back tires once LOL
Mike Taylor 3601
Old 12-26-2013, 02:54 PM   #16
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Our stockers running mid 10s typically had a 1.48 60ft with rear tires and it was 1.33-4 with the front tires. However, the faster a car is the less et difference will be seen. So, if it's a low 9 second car it's probably around .12. A mid low to high 10 second would probably be .14-.16. However, if it is tripping the beams with the middle of the car, you can have inconsistent numbers. I have seen runs .05-.06 slower in 60ft with same 330 on my high 9 second Firebird.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 12-26-2013, 04:57 PM   #17
Don Higgins
Subtract .10 - .145 depending on weight from the back wheel 60 foot and you will be close.
Don Higgins - Super Comp #360H
Don Higgins is offline   Reply With Quote
Old 12-26-2013, 05:34 PM   #18
Jeff Teuton
Liked 325 Times in 50 Posts
Country puppy has it about right. It's a calculated guess, look at 330 also.
Jeff Teuton 4022 STK
Old 12-26-2013, 08:13 PM   #19
Ed Wright
Ed Wright's Avatar
The 60' beams are 8" off the ground, right? You would have to be almost straight up at 60' to catch it with the rear tires, and not the rocker panel. How high the front determines where along the rocker panel the beam catch it. Normally I'm 1.27X to 1.28X, straight up I'm 1.4X.
Ed Wright 4156 SS/JA
Old 12-26-2013, 08:36 PM   #20
HP HUNTER
Originally Posted by ed wright View Post
the 60' beams are 8" off the ground, right? You would have to be almost straight up at 60' to catch it with the rear tires, and not the rocker panel. How high the front determines where along the rocker panel the beam catch it. Normally i'm 1.27x to 1.28x, straight up i'm 1.4x.
1.40-1.28 =.12
