Liked 15 Times in 11 Posts
You didn't mention what class you run with your Nova or if it is a bracket car. Either way changing the upper A-arms won't fix the bump steer issue your having. Install a Bump Steer Kit and play with the adjustment until the lower A-arm and tie rod move in the same arch. I had the same problem on my Camaro and the kit solved the shimmy problem.
