Old 11-02-2013, 12:27 AM   #1
Jeff Lee
Jeff Lee's Avatar
Default Re: Jeff Lee DQ'ed
With no time to T-N-T as I would have liked ( car ran on its own for 1st time Wednesday night around 10:30), we found out the hard way there was not enough tire clearance to the left slick on the 96" 30" roll-out Hoosiers (previously always ran 91"-92" 29.5 M/T's), which I've stated elsewhere.
My 1st pass left some nuts that were in the trunk along with fuel from the fuel cell vent on the starting line along with heavy tire smoke in 4th. Bring on cleanup crew for 20 minutes. 2nd pass was same problem less the nuts & again 20 minute delay as NHRA checked the track & cleaned up the fuel.
D7 Tech director Ben told Rob Youngblood (as we were pitted together) that if I caused another delay, I'd be DQ'd. Rob told them we had the problem licked (or so we thought). Made 3rd run same problems, same delay.
So I spent the next few hours with a body grinder & tin snips only to find they meant what they said. The clearance is finally right (so I hope) and the vent was re-routed. Causing 30-45 minutes in delays is understandably frustrating and a burden on those racers following me so I certainly understand. I just wish I could have had time for a T-N-T but I wanted to make the last D7 race of the year. Sorry to those that had to endure the delays!
Jeff Lee 7494 D/S '70 AMX
Old 11-02-2013, 12:47 AM   #2
SStockDart
SStockDart's Avatar
Liked 606 Times in 213 Posts
Thanks for the post, and "getting out in front of the situation" before everyone starts speculating.... Many of us have been DQ'd (me included) and it is not the end of the world. Good running....
Old 11-02-2013, 12:51 AM   #3
Gordie Kissner
Liked 18 Times in 10 Posts
Hey Jeff,
Less the bugs with tires/fuel, I would say you had a pretty solid first outing! Congrats and good to see the car out again!
Gordie Kissner
SS 6010
STK 6010
Gordie Kissner is offline   Reply With Quote
Old 11-02-2013, 02:01 AM   #4
Jeff Lee
Jeff Lee's Avatar
Originally Posted by Gordie Kissner View Post
Hey Jeff,
Yep...first D7 race is February? All bugs will be ironed out
Old 11-02-2013, 09:12 AM   #5
FINESPLINE
FINESPLINE's Avatar
Congratulations Jeff, I know its been a long time and a direction change or two but the you are there. Looking forward to your 2014 debut and a first full clean pass. Time to fix the bugs and get ready for the holidays. Best wishes, John
FINESPLINE is offline   Reply With Quote
Old 11-02-2013, 10:57 AM   #6
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Jeff sorry about the dq. More importantly congrats on getting back out there, and a great first showing it was. Have fun tuning it up for next year
Chris
chris ok is offline   Reply With Quote
Old 11-02-2013, 11:02 AM   #7
K Stubbs
Liked 20 Times in 3 Posts
Look on the bright side Jeff, that gives you some time to pick up the three tenths needed to set the record. Congrats
K Stubbs is offline   Reply With Quote
Old 11-02-2013, 11:22 AM   #8
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
maybe if you spent less time on this forum telling us how smart you think you are and more time fixing your junk, you wouldn't have delayed every racer 3 times nor been DQ'd!
Old 11-02-2013, 11:41 AM   #9
Frank Castros
[QUOTE=1320racer;406902]maybe if you spent less time on this forum telling us how smart you think you are and more time fixing your junk, you wouldn't have delayed every racer 3 times nor been DQ'd![/QUOTE
Kenny,
Isn't time to pull the plug on this1320racer guy?
Congratulations Jeff on your return, and I'm sure you'll get it straightened out.
Old 11-02-2013, 11:55 AM   #10
james schaechter
Thumbs down Re: Jeff Lee DQ'ed
All opinions aside about Jeff, kicking a guy when he is down, is in poor taste.
Maybe you should try racing a stick stocker sometime.
I am sure you would figure it out in a couple passes.
I could use some of your sage advice....
James Schaechter 3163 STK
