Old 10-17-2013, 11:17 PM   #1
SSDart
Default Re: questions about low 1st gear
Originally Posted by hardtimes View Post
so what can/should he do to try to get the car to wheelstand better?
rear gear/trans gear/converter ?
Proper shock settings, dynamic adjustable strut rods and min 5 inches front travel before you consider playing with gearing or god forbid some message board know it all's GUESS at your converter needs..............
SSDart is offline   Reply With Quote
Old 10-18-2013, 09:50 AM   #2
Ed Wright
Ed Wright's Avatar
Everything he ^^^^ suggested, and free moving control arms. With the ball joint not connected to the spindle, raise the ball , then let go. Should drop. You can always slow it back down with the shocks and take travel back out with travel limiters on good starting lines. You should be fighting excessive wheel stands (they will cost you a couple hundredths) , not wheel spin.
Ed Wright 4156 SS/JA
