#1 | |
Liked 759 Times in 379 Posts
so what can/should he do to try to get the car to wheelstand better?
rear gear/trans gear/converter ? |
need to know more about the current combo as it stands. Converter is critical as well and can't be compared by size and stall alone.
408W 10.5:1 compression
AFR 185 heads hydraulic flat tappet 240/246 541/544 106lsa Victor jr intake Holley 950HP 1 3/4 headers C4 8" ATI 4.33 gear M/T 28x10.5 bias stiff sidewall 3100lb w driver |
Based on the info you provided, this engine is making less than 500HP. He probably is shifting a few hundred RPM too high and the converter is a few hundred too loose. More rear gear will help providing he can hook. A move to a 4.71 gear should be worth at least .02 in 60 foot but will have him turning upwards of 500 RPM more at the stripe which isn't a bad thing providing his valve train is up to the task.
gear change to 4.71 will tighten the conv
agreed, that's why it was suggested
Proper shock settings, dynamic adjustable strut rods and min 5 inches front travel before you consider playing with gearing or god forbid some message board know it all's GUESS at your converter needs..............
Everything he ^^^^ suggested, and free moving control arms. With the ball joint not connected to the spindle, raise the ball , then let go. Should drop. You can always slow it back down with the shocks and take travel back out with travel limiters on good starting lines. You should be fighting excessive wheel stands (they will cost you a couple hundredths) , not wheel spin.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 10-18-2013 at 09:54 AM. |
