Liked 520 Times in 132 Posts
I run a Deano 4gc with a heads up spacer. 7 psi leaving at 9000 in the air never a problem. This is the angle spacer. I was told you cant run a flat spacer with a 4gc.
Liked 99 Times in 49 Posts
As I said have wedge spacer ran fuel psi where Deno told to start.I dont have hood cl for more than 13/4 inchs
You can angle mill the carb flange as well as running a wedge spacer.
Jeff Lee 7494 D/S '70 AMX |
Liked 1,428 Times in 296 Posts
Maybe try lowering the float a bit. I tend to run the float in the 4gcsin my sticker just a bit lower than Deano has them set.
One thing that the guy from Product Engineering mentioned to me once had to do with fuel regulator mounting position. At the time, he was talking Q Jets, but his concern was a fuel regulator being mounted ahead of the carb. He said the g force of the launch could hit the needle on the launch and blow it off of the seat. Our stocker would leave pretty high in J Stick at 7200 with no issues. Stock manifold with no wedge, just felpro base gaskets.
James Schaechter 3163 STK |
Liked 4 Times in 1 Post
Try lowering the fuel pressure even more, as low as 4 or 5 lbs. It works for Q-Jets.
I know it sounds backward, but what have you got to lose?
Tony Curcio 1860 STK |
Angle mill the flange on the intake manifold
Dion Hildebrandt 6009 STK H/SA |
