Old 08-09-2013, 06:51 PM   #1
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
Default Re: goodyear 1909 slick
Originally Posted by John Nechiporchik View Post
Joe, Will be in the market to replace my 1909's soon. How do the Hoosiers you mention compare ,performance wise , to the 1909....if you have experienced them as well.
Are you going to 131 (IHRA) this weekend?
John, the 1909's would not fit on my car. They were a bit too tall. I've heard great things about them though. I did try the 9 x 30 D4A compound once and was not impressed with them. They were good about the first 20 runs and that was about it. The Hoosiers are consistent throughout and last much longer. I will not be at 131 this weekend.
Joe Martens AA/Stock 3969
Joe Martens is online now   Reply With Quote
Old 08-12-2013, 06:57 AM   #2
Keith Bennett
Keith Bennett's Avatar
Liked 70 Times in 36 Posts
Send a message via MSN to Keith Bennett
Joe,
What gear do you run using the Hoosier tire?
Thanks
Keith
Keith A/S 2990/Terri A/SA 2991
"Imagine what you'd attempt, if you knew you could not fail!"
Keith Bennett is offline   Reply With Quote
Old 08-12-2013, 09:10 PM   #3
John Nechiporchik
Liked 13 Times in 7 Posts
Joe, What tire pressure are you running with the Hoosier?
Put a new set on Saturday, ran at 10 and 9 on two respective passes.....spun like crazy.
Talked to Hoosier today, they felt I need to up it to around 12.
I'm on a 10 inch rim BTW.
Lost .04 in the 60 ft. and the video shows excessive spin. Data recorder was not working, so no hard data other than the 60'.
Any help/advice is appreciated.
John Nechiporchik is offline   Reply With Quote
Old 08-14-2013, 06:34 PM   #4
Joe Martens
Originally Posted by Keith Bennett View Post
Joe,
Thanks
Keith
Keith, sent you a pm.
Old 10-26-2013, 10:23 AM   #5
jscamaro1
Liked 3 Times in 1 Post
How many runs are you guys getting before the Do7's seem to go away?
I run a 4 speed car similar to an A/S, and get about 40 to 50 runs. Did not know if that is pretty consistent with A, B/S guys are what.
Don't know about the goodyears but when the Hoosier's go away they go away very quickly!!!
jscamaro1 is offline   Reply With Quote
