Old 06-24-2013, 10:21 AM   #6
Sean Marconette
Sean Marconette's Avatar
Liked 282 Times in 78 Posts
Default Re: Maximum rear wheel spacer vs. safety issues
The key to running spacers is what Larry pointed out. They need to fit snug on the wheel stud, and have adequate torque applied. The 5/8" studs do not allow for a shoulder style lug nut. The problem with running spacers with 1/2" studs, is the engagement of the lug nut shoulder allowing flex in the stud. If the stud is allowed to flex, you will have bad things happen. After having 4 out of 5 wheel studs break when I first got my car back together several years ago, I was running 1/2" studs with spacers. The stud was flexing at the brake rotor hat, as the lug nut shoulder did not engage in the full depth of the spacer. Since switching to 5/8" studs and billet spacers, I have never had an issue. When servicing the brakes, I have to work the spacer off the studs to remove them.
Get the tire and wheel to fit the car with spacers, then if you choose to buy a custom offset wheel you know exactly what you need.
Sean
Sean Marconette
84 Mustang
5060 SS/N
