Old 06-20-2013, 03:24 PM   #1
Liked 5,134 Times in 1,958 Posts
Default Re: Some "Dime Rockets" for the 4TH!
I think Yac had one at the USCN race and asked me what I thought of it. I told him I thought it looked like a cylinder head.
Actually ,Dwight, that was a 3.8 (a whole 'nother story)
I never paid much attention to the 60 deg. V6..but knowing what we know now, it might be worth a second look.
Near as I can tell ,it's a 2150 with a 1.08 venturi...Same as the 77 302!
A little more cam lift, and about the same compression..
The short stroke hurts the low end torque ,but it should rev pretty high with that carb on a small c.i. engine.
Cam cores might be a problem.
It seems that there WAS a C4 offered with the Taunus bell housing pattern, which you'll need...(not a C3)
There are some minor differences in the various years. I haven't looked that close
Your job!
I see it as an easy .5 under deal, if you can find .030 over OEM pistons.
More than that, if you want to invest in a 7" converter.
Old 06-20-2013, 09:04 PM   #2
mtkawboy
Liked 54 Times in 18 Posts
Heres a tip on the clever engine design. Lifters must go in before heads go on or they wont go in at all. Yes, Im serious ! A lot of people learned that one the hard way
mtkawboy is offline   Reply With Quote
