Liked 2 Times in 2 Posts
Thanks Billy I had the 78 LT as a T/SA .I can find a ton of 305 cores around here from the late 70's
Liked 99 Times in 21 Posts
I was looking in the guide and found a 1978 pinto wagon with the 2.8 V6 2bbl. it is rated at 120hp, factory weight of 2645# and is on a 22.04 weight break (V-stock). Has anyone ever ran one of these? I think it was rated about 6 hp more than the 2300, but has .5 less compression, and smaller valves and cam. Does this engine have any potential? Don Jackson
#3 | |
Liked 7,730 Times in 1,739 Posts
Liked 4 Times in 4 Posts
Grab the old book "V6 Performance" from Pat Ganahl, there is some cool info in there. As for the car, I can find them relatively easily in Montana, they were my nemesis in my compact demolition derby days...guys around here hoard the wagons.
Liked 780 Times in 194 Posts
#6 | |
Liked 5,121 Times in 1,952 Posts
I never paid much attention to the 60 deg. V6..but knowing what we know now, it might be worth a second look. Near as I can tell ,it's a 2150 with a 1.08 venturi...Same as the 77 302! A little more cam lift, and about the same compression.. The short stroke hurts the low end torque ,but it should rev pretty high with that carb on a small c.i. engine. Cam cores might be a problem. It seems that there WAS a C4 offered with the Taunus bell housing pattern, which you'll need...(not a C3) There are some minor differences in the various years. I haven't looked that close Your job! I see it as an easy .5 under deal, if you can find .030 over OEM pistons. More than that, if you want to invest in a 7" converter.
Liked 54 Times in 18 Posts
Heres a tip on the clever engine design. Lifters must go in before heads go on or they wont go in at all. Yes, Im serious ! A lot of people learned that one the hard way
#8 | |
Billy, I done a little digging and it looks like the stick has the 2150 motorcraft and the auto has the variable ventura 2700. Cant find a ventura size anywhere. Did find a CFM chart
.98=190cfm, 1.01=240cfm, 1.02=245cfm, 1.08=287cfm, 1.14=300cfm, 1.21=351cfm, 1.21=351cfm, 1.23=356cfm, 1.33=424cfm, for the 2100 and 2150 carbs. I am ASSumimg the variable ventura is only one size, can't find much on it other than it came on engines from 171ci to 351ci. it might be pretty big if the engine will pull enough to open the vents fully. Don Jackson |
#10 | |
You don't need a Pinto wagon though..In fact, you don't even need a Pinto. Mustang II is the way to go. If all else fails, go with a 302. *Actually, you can use a Fox body 79 too..Still with 2150 1.08 carb
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 06-20-2013 at 10:59 PM. |
