The c12 fuel I ran in my car this weekend at mission was from last July when I bought it for Woodburn. I had half a tank sitting in the car since then, and 3 plastic 5 gallon jugs sitting under a tree in my back yard out in the elements. all this fuel tested perfectly every time.
#2 | |
Ed Wright 4156 SS/JA |
Only problem with C-11 is the price! Lower octane, yet cost more than some of the higher octane fuels.
4878 SS/GA 66CHEVY II |
Darren, in my car it's a tad faster on C11 after adding about 5% WOT air/fuel. More octane than you need costs a little power. Of course, in slow down mode that doesn't matter. :-)
Liked 524 Times in 141 Posts
Isn't C-11 a little quicker burn rate than C-12? No?
Lower octane doesn't hurt as long as you are not detonating. A quicker burn rate is....well....quicker. I can see how C12 would check ok in Mission. I think it has a harder time in the heat of our area if not properly stored. And sometimes it will be marginal right out of the drum. This also may be due to their testing equipment at the tracks. |
C11 has a much lower specific gravity than C12. The lower the specific gravity the faster it burns. Faster burning means more power. You aren't paying for octane you are paying for the properties that make it have a lower specific gravity.
Dave Ley |
Thanks for the explanations guys.
Specific gravity C-11 .710 @ 60* F C-12 .717 C-14 .696 C-16 .735 C-25 .695 At No Problem Raceway for the D4 race C-11 and C-16 were $16.00 per gal. and C-14 was $14 per gallon. Sorry for getting off the original topic. I do run C-11 with no problems at fuel check as of yet, but I'm new to this super stock stuff. Maybe I should try some C-25, I could use all the help I can get.
4878 SS/GA 66CHEVY II Last edited by Darrin Christen; 06-18-2013 at 10:56 AM. |
Liked 10 Times in 6 Posts
#9 | |
The testing equipment looks like something from the 80's. Maybe it isn't that critical, but I am not the first to question how up to date their equipment is. Last edited by KRatcliff; 06-18-2013 at 11:10 AM. |
Liked 89 Times in 28 Posts
The real problem is the way the testing process is set up. To be clear the parameters or window that the fuel is suppose to test within.
When I've been close to failing fuel check it's always been on the low side. A few years back at Sonoma many of us were close to failing or failing. I went and bought a fresh 5 out of a new drum. They tested it for me and said it was perfect, right in the middle. Why if when we fail it's always on the low side, but when the fuel is fresh it only starts out life in the middle? Shouldn't it start out life at the top of the scale??? |
