Old 06-12-2013, 08:14 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: removing rod caps
Clamp the rod in a vise on the big end cap. Use something to protect the rod surface....soft jaws or cardbaord can be used. Make sure it is tight....
Grab the rod at the beam and rock it as you pull up....once it moves a little they usually come right apart...
They do make a rod cap spliiter but I never have a problem getting them apart using the vise technique....
Rich Biebel
S/C 1479
Stock 147R
