Old 06-03-2013, 09:25 PM   #1
racer913
Default fuel pump
new fuel pump has a leak from time to time is this a weep hole? this a sign of internal problem pump is less then month old
racer913 is offline   Reply With Quote
Old 06-03-2013, 10:13 PM   #2
race watcher
Default Re: fuel pump
Internal problem with bearing and/or seal. Had the same problem recently. There should be no fuel at that area.
race watcher is offline   Reply With Quote
Old 06-04-2013, 09:25 AM   #3
FED 387
Liked 333 Times in 180 Posts
CALL Magnafuel tell them your symptoms they are very good about standing behind their products--FED387
Old 06-04-2013, 09:23 PM   #4
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Exclamation Re: fuel pump
Get the parts and fix it (bearing and seal)
The gas washes the grease out of the bearing and it WILL fail!
Glen DeMenge
MEXJOE is offline   Reply With Quote
