#1 | |
I have a question, in the Schubeck thread, you stated that you use Schubeck lifters and now on Trend you say you use Trend. Which is it that you use. Also, what engines do you have running Trend and what is running Schubeck. I would also like to hear your answer on the EDM hole. I work at a Industrial machine shop and I do a lot of close tolerance work for some of the local racers racers. I do get to see inside some of the engines but I by no means am a engine builder. just a lurker that gets to help. Geez could you run that kind of spring pressure on trend lifters. I do not see how. charles |
#2 | |
Liked 1,954 Times in 440 Posts
It depends upon the application. In the case of our own personal engines, we bought several sets of Shubeck lifters before Shubeck closed, and before Trend began producing tool steel lifters. So, we use the Shubecks we own personally in our personal engines, for now, as we've run the same engines for quite a while. I have the Trend lifters in customer's engines, and I've sold several sets of Trend lifters to other engine builders who are not on the Trend program. We have both Trend and Shubeck in big and small block Chevy as well as small block Ford engines. With the proper setup we've run as much as 260# on the seat and 525# open on the Trend 0.842" lifter. It takes a nitrided camshaft that has been micropolished, the correct assembly lube, the correct break in oil, and the correct break in procedure. I know a couple of engine builders who run the cam in with a set of Shubecks they keep for that exact purpose, then swap to the tool steel lifters, and finish the break in. A couple of the guys at Trend have advised us not to run the EDM hole, and we've had no failures. It is their product, I take their advice until I see the need to do otherwise.
Alan Roehrich 212A G/S |
