I have two just like these. destroyed a brand new L-88 on the dyno on second pull. it will cost a whole lot more than 1.500 to fix.
Trashed: Cam Lifters Push rods Pistons Rings Block Gaskets & labor Larry ![]() |
Liked 43 Times in 29 Posts
Has anyone every put a paper and pencil to the advantages of running Schubeck lifters say in a sbc 327 as it relates to et. I just wonder is it really worth the expense and potential destruction of a good piece.
Mark Ruset 2048 STK |
Are you sure that piston to valve clearance is enough?
What about the condition of valve springs? I would really recommend you to inspect faces of valves and valve notches on pistons for even the smallest sign of contact, especially at the cyl. with broken lifter. The ceramics seems not to cope with any axial pounding at all. I learned my lesson really good last season, wiping out two cams etc. etc. Also learned that total dismantling of everything, and throughout cleaning after the failure of a Schubeck lifter is absolutly necessary, since the remains becomes an exellent grinding compound... Schubecks seems to be great as long as they dont take a lot of pounding. |
I won't be using Schubecks again. I got pretty lucky this time. It happened in the middle of 3rd gear, when the engine suddenly laid down and missed. I thought I had just punctured one more rocker arm, but I DID IMMEDIATELY drop it in neutral, to idle, and shut the engine off. Coasted a 1/4 mile to where my truck / trailer was parked, and rolled right up on the trailer ! ( VERY easy loading trailer ). Pulled the cover right there, and that's when I discovered the issue with the "loose rocker".
My engine had about 2 1/2 hours on it. Cam.. scored a bit from the edges of the lifter, but otherwise OK ( Of course it gets changed ) Cylinders... a bit of scoring opposite thrust side. It'll hone out Pistons... skirt coating didn't hurt. I measured... should be able to prep and re-coat. ( VERY loose ! ) Oil pump... un-marked Crank... un-marked Bearings... I'll be changing them Heads... untouched I do my own work, so I never figure the HORRIBLE job it is to R&R the engine ! ( first driveshaft at transmission, then scattershield and headers, then work on engine removal !... and the engine has to be out in order to remove the pan ) So... Complete disassembly, BIG wash job... and fix it faster ! Doubt it'll be running this season though. From now on, this thing gets no money, unless it comes from something else that I sell ! Mark, this is just my take on it... Performance advantage of the Schubecks ? Probably 1 horsepower ( reduced friction ) Really what they do, is tolerate the ridiculous ramps on Stocker-type flat tappet cams... which are the heart of the horsepower. Probably worth 50+ horses. Because of course due to the Stock rules, piston-to-valve clearance is at a minimum. Mine measured .070" on the intake, .045"+ exhauast ( cam is retarded 4 deg ). Pistons are "clean" in the area where the exh valve gets close, but no evidence of contact. My rocker arm "puncturing was actually more prone to the intake... the ramp on the intake lobe is a little more aggressive ). I still have never wiped out ( or even hurt ) a cam lobe, in any engine. ( knocking on my head right now ! ) My plan is to change to the products from Performance Research. IE, tool steel lifters, steel billet cam... that's why no-rebuild anytime soon !
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
Liked 544 Times in 213 Posts
Advance the cam and you'd have a little more exhaust clearance. Yes you'd lose intake clearance but since your exhaust side is so tight, I'd move it.... What lobe was the lifter that broke exhaust or intake? I'm not saying it hit since you say there is no mark but I'd be more comfortable with a tighter intake side and most engines like the cam advanced. Shubeck lifters appear to have a real high failure rate and if they have a specific running clearance to the lifter bores......why isn't that info given to the buyer of the lifters!......The Nascar stuff looked like the way to go.......
#6 | |
Yes Rich, I agree, more clearance at the exhaust would be desireable.
However, the engine seems to have responded VERY well to the "late" cam. Above 6000 is a different animal all together. Also, it's of course a stick car, and never sees below 3500 at any time during a run... and still has a terrible traction problem. Hans, I check piston-to-valve by the "light spring" method. My "close" spot,is about 10- degrees before TDC on the exhaust valve. oh yeah... it was an intake lifter... hot clearance had been set to .014" ( .016" hot by the cam card from Comp )
#8 | |
What spring pressure do you use? The "light spring" method shows the least amount of clearance does it not? |
oh yes, spring pressure...
250-255 seat... around 470 open. The valve clearance ? just geometry... ! pre-assemble everything, and check the "lash" ( measure with a dial indicator, the distance you can push the valve to the piston, when the crank / cam is positioned near overlap ). really, very easy to do. be sure to check in various postions.
Liked 6 Times in 2 Posts
Can anyone tell me the correct lash on Shubecks Hyd, 70 Ply RR 440. 6 Pak Got 34 passes and alls well. The reason i'm asking is i set them at .004 which i was told on this board, and i'm just wondering if that is close to right . John
John Lang 365 STK, SS |
