Old 04-22-2013, 10:07 AM   #1
pontiacchuck
Default Re: Under the index for under a grand!
Originally Posted by billy nees View Post
at 8:30 this morning it started and ran. At 9:30 it was at "the beav". At 10:45 it made it's first pass down a racetrack.
Did it run the index? Yes and no.
Is it a good car? Yes and no.
And the biggest question, is it under the budget? I don't know, i've got to add up the receipts.
Tomorrow, i'll give a "blow-by-blow" of the engine and installation!
ok tell us what happen no more wondering did you go under index and what times ha ha and did you keep in the budget
pontiacchuck is offline   Reply With Quote
Old 04-22-2013, 08:02 PM   #2
Billy Nees
Liked 7,758 Times in 1,741 Posts
Proof that the engine is in the car and my nifty $39 Sun gauges(Advance Auto, fit right in the air vents like they were made for it) and $25 tach.
ID:	18623   Click image for larger version
ID:	18624   Click image for larger version
Billy Nees 1188 STK, SS
Old 04-22-2013, 10:36 PM   #3
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Nice job old man ruining a mint crash pad with that 1" hold down bolt.So how much under did you go?Where's the Billy tubes?
Former NHRA #1945
Former IHRA #1945
T/SA
Old 04-23-2013, 10:04 AM   #4
Billy Nees
It's time for me to talk about the engine. It's a 301 2V factored to 155 hp. The car has to weight 3270 for U/SA and it's auto only.
When I first started playing with 301s I found an 80 GP 4V 310 to take to the track and abuse and learn from. When my buddies found out that I was playing with them they started looking for parts for me. One of the parts that turned up was a "Jasper rebuilt" shortblock that was bought for a job by a N.J. shop and the job never got done. It sat under a bench for years open and basically being a garbage can. A buddie saw it sitting there and asked about it, heard the story and asked if it could be bought. $200 later, it was mine. It had to be completely disassembled (which should be done with any engine, IMHO), cleaned out and checked out. It is .030 over, has NHRA approved pistons in it(Silvolite), .010/.010 crank and good old cast iron rebuilders rings in it. I didn't deck the block or turn around pistons or anything like that, I just wanted a good sealing, sound shortblock to learn the combo. It has fit the bill very well.
For this project, it got "cleaned out" one more time, reassembled with the original parts and made ready to go again.
I selected a cam that is rather different from my 4V 301s in that it is smaller @ .050 to try and build more cylinder pressure and try and make more torque at a lower rpm. One of my "failure" cams was sent out to be reground and that bill came to $80. I've already talked about the heads so with some help from an eagle eyed friend, some dirty work, a reground, preowned cam and a $45 gasket set (dime rocket tip!!! don't buy gaskets seperately, buy an engine set!), I've got a shortblock.
There are lighty used and unused shortblocks out there! They just need to be found. Just looking on e-bay in doing some research, I was able to find 302 Fords and V6 Buicks for under $500. The thing that you will want to check is just what piston is in them. Is it NHRA approved? If not, how much can you buy a cast, legal piston for? And if you do buy, always disassemble and inspect!
OBTW, one more "Dime Rocket" tip, I don't know how long this is good but "NAPA $19.99 synthetic oil change AND filter". 5 qts. of NAPA synthetic oil(Valvoline) and NAPA Silver filter(Wix). You can't beat that for under $20! Just don't forget the zinc additive.
Old 04-23-2013, 08:59 PM   #5
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
Best affordable engineered award.
Old 04-24-2013, 08:42 AM   #6
Billy Nees
"The Budget";
trans and converter $80
rear $100
wheels and tires $35
tach and gauges $64
driveshaft loop $8
fan $10
fuel system $55
electrical system $37
brake system $10
engine assy $423
total $822
I didn't include sparkplugs or fluids as they would be needed for anything that you would be racing or driving. If you feel the need to then plug in a number. I also didn't itemize, I'm not an accountant.
Next time, "The Payoff".
Old 05-21-2013, 08:45 AM   #7
Billy Nees
"The Budget";
total $822
I did manage to drive the car around in the rain on Sunday with the new converter and I can say that it's definitely "different". Although it is a 10" converter, it seems to hit like a tight 8" converter. I guess that I'll find out on Friday.
Time for a budget update, the new converter was originally quoted to me at $250-$275. Picked up at the door price, $200! I've gotta love that!
total $822
-$80
=$742
+$200
=$942
I'm still under but not by much! Fingers crossed, heading for The Grove!
