Old 04-21-2013, 09:51 PM   #1
kansas stocker
Liked 249 Times in 48 Posts
Default Re: Oil Filters?
Yes.
Pete
kansas stocker is offline   Reply With Quote
Old 04-22-2013, 06:54 AM   #2
steven reynolds
Liked 13 Times in 11 Posts
Originally Posted by kansas stocker View Post
Yes.
Pete
Agree completely had a 68 GTX 50 pounds oil pressure wix filter changed oil and filter fram 5 days later 0 oil pressure filter paper in oil pump and passages DO NOT USE FRAM!
Steve
steven reynolds is offline   Reply With Quote
Old 04-22-2013, 07:09 AM   #3
Bob Bender
Bob Bender's Avatar
Liked 459 Times in 90 Posts
Wix Racing filter the BEST !!!
Bob Bender 144 O/SA
Old 04-22-2013, 07:42 AM   #4
art leong
My filter is positioned after the pump.
Art Leong 2095 SS
Old 04-22-2013, 08:08 AM   #5
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Art, yes a filter can affect oil pressure. The differance's in the filtering elements can either cause more or less of a restriction and in turn drop or raise oil pressure. I have seen over 10 psi change from differant filters
Chuck
C and W Racing is offline   Reply With Quote
Old 04-22-2013, 11:55 AM   #6
DonatoEng
Liked 8 Times in 5 Posts
Artie,
The Viper filter is one of the best, has a low restriction element with a high burst canister. It will result in a lower pressure reading at idle but it has a higher flow rate cause at high rpm's.
There are several part numbers available and one of them had some issues, will have to check.
John
John Donato Stk / SS 3435
DonatoEng is offline   Reply With Quote
Old 04-22-2013, 01:24 PM   #7
FED 387
Liked 332 Times in 180 Posts
Not positive but I seem to think that the P4529190 filter has a bypass of like 8-10 PSI and a flow rate of 28-30 GPM vs. the "stock type " Neon filter which has a bypass of like 25-30 PSI and a flow rate of only 7-9 GPM--probably why the pressure is coming up so low----less restricton and more oil flowing(volume) ---put a wix 51515R on it and see what happens they are really the way to go---otherwise put a Peterson in line filter on the inner fender but then you hafta run braided line and all----FED387
Old 04-23-2013, 09:47 AM   #8
art leong
Originally Posted by DonatoEng View Post
Artie,
John
Hi John the part number is 05281090
Art Leong 2095 SS
