Liked 2 Times in 2 Posts
I replaced my BG500 with Weldon and won IHRA Div 1 Hot Rod Championship the same year. Weldon makes a great product.
Liked 333 Times in 180 Posts
Bricki--- probably that fuel line is too small and you might have a lot of bends in it which will either cause restriction or aeration of the fuel---- remember pressure is one thing volume is another---- try to take the pressure closest to the carb---also when setting the pressure with an Aeromotive remember that the engine MUST be running you cannot do it correctly with the engine OFF!!!! I don't think you need a return line with that low of a HP engine either.
Bricki--also forgot to mention since you are using a bypass/return line system the relationship of the placement between the pick up line and the bypass line is critical also to prevent aeration or foaming of the fuel--FED387
