Liked 240 Times in 112 Posts
What does your stocker 60 ft & is that with/without a "low" gear set in the trans. Just seeing roughly where I need to be.
Dave Noll, EF/S ,?/SA 6526 |
Liked 79 Times in 11 Posts
mine was 1.60 to 1.65 with a stock c-4 ratio.
bob beals 7244 |
Liked 5,140 Times in 1,962 Posts
We have been 1.55 in O/SA...350 Buick, 2.74 low, 4.56..,245 mm converter
That would be kind of an outlier on the graph though...
Liked 905 Times in 193 Posts
Best of 1.62 in N/SA.
Bob Don 128 SS |
Liked 719 Times in 220 Posts
1.65 in O. It's a rather heavy Chevelle station wagon.
1.59 in M, 273CI, 2.74 first gear, 4.86 in the rear.
F504 C/SA , Tracy Fairchild |
1.498 @ Sea Level
0/SA dodge Wagon 318 Low Perf. small valve 3625 Lb. Usually `1.52 to 1.54 Loooooooooow Gear Pro Trans with Straight Cuts and all Goodies. |
Liked 49 Times in 22 Posts
My M/Stick car only runs low 1.6s to 60 feet, I am sure that the combination of a fat driver (no ballast in the trunk), and bias slicks likely do not help. I do not know how other lower classed stick cars compare to similar automatics.
26 tall, 8 wide. About all the room there is.
elev. at Brainerd where I mostly run is 2500-4000 feet.With a low barometer.
