Old 03-28-2013, 09:48 PM   #10
art leong
Default Re: Cylinder problems?
Originally Posted by Kegracing View Post
What else on the ignition system for this hole? Wires, coil?
I had a plug boot with a crack that did a plug like this one time. Not a dead miss, but not full burn either.
Just guessing.
Good luck.
Ken
Changed plug wire when I changed plugs.
I'm going to switch injectors and see if I can change cylinders. If not. The coil is the next thing to change.
I don't want to pull the head just yet. Once I do if it is something else I'll have to find it after it goes back together. Want to try the easy stuff first.
Art Leong 2095 SS
