Old 02-21-2013, 09:46 PM   #1
SSDiv6
Liked 1,580 Times in 582 Posts
Default Re: Thoughts on running a 1985 Buick Riviera
Thanks Rick ,Bob..
You know, the elec. version 440 O.D. trans, started out as the 125 3-speed, so a lot of the parts will interchange and therefore would be just as strong.
The 125 is actually similar in function to the T 200 ...so low drag tricks would apply there as well.
There's a little hint for somebody out there ...;-)
Mark,
The later models have a 4T65-E in them. I used to own a 1995 Bonneville SSEi with the 440 version and a 1998 which had the 4T65-E.
I did many mods such as pulley, headers, Magnaflow exhaust, trans mods, changed coils, cooling fan sensor changed, better fuel pump and had the ECM recalibrated. The Bonneville is way heavier than the GP and I made a pass with sticky tires and went 13.65.
There is a lot of aftermarket parts out there to make one go pretty fast.
There is also a link for the Factory GM racing Manual for the 4T65 Trans:
http://cowan1984.xtreemhost.com/gmtu...build_book.pdf
For my trans, I got the trans from Trasher:
http://www.3800performance.com/Merch...ode=TEP-TRANNY
Old 02-21-2013, 11:12 PM   #2
Liked 5,121 Times in 1,952 Posts
Mark,
Right.
What I said... From Wiki :
The 4T60-E (and similar 4T65-E) is a series of automatic transmissions from General Motors. Designed for transverse engine configurations, the series includes 4 forward gears. The 4Txx family is an evolution of the original Turbo-Hydramatic 125 transverse automatic introduced in the late 1970s.
The "-E" transmission is electronically controlled and features an automatic overdrive transaxle with an electronically controlled torque converter clutch.
Maybe some missed my point: Stockers don't need to run 4th gear overdrive.
Old 02-23-2013, 02:55 AM   #3
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
The Riv that ran Div. 1 was Tony Massari (of Yoo Hoo Too fame).Unfortunatly he smacked the wall at the Dutch (think it was that race) on the top end.Did enough damage to end it's career.Tony called it quits too.It was a fairly rare car,only a few hundred made I believe.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-24-2013, 10:51 AM   #4
Joe Toller
Liked 4 Times in 4 Posts
The turbo Riv was actually one of the more common of the Turbo Buicks in the early (78-83) era. The intake and turbo differs from the Regal/Century/Lesabre. I have a wrecked 79 in my stash, mainly for the longblock.
Old 03-24-2013, 11:35 AM   #5
Bob Shaw
Liked 316 Times in 61 Posts
I have a rare 1985 Riviera T-Type V6 turbo efi (same engine as the Grand National) that I would sell. I was planning to make it a race car but it never got to the top of my list.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
