Old 02-15-2013, 11:00 AM   #1
denbreeden
denbreeden's Avatar
Liked 67 Times in 27 Posts
Default Re: New for 2014
Originally Posted by KRatcliff View Post
I agree with you. My nuts are locked and don't fall off.
Some guys have their wife keep their nuts in her purse...
Dennis Breeden
denbreeden is offline   Reply With Quote
Old 02-15-2013, 11:07 AM   #2
T Ketels
So their tabs with a bolted construction is better than tabs welded to the tube with one of our bolts. Oh yeah, their design is far superior as it has two additional ferules with yet two more connections. After all, four connections are greater than two!
SS/MA
5017
T Ketels is offline   Reply With Quote
Old 02-15-2013, 11:10 AM   #3
KRatcliff
Liked 534 Times in 143 Posts
Dennis Breeden
Well....at least they are safe and won't hit someone during a burn out.
KRatcliff is offline   Reply With Quote
Old 02-15-2013, 12:13 PM   #4
bert powell
Liked 34 Times in 12 Posts
Originally Posted by Pedigo Perf View Post
I suppose another way NHRA could address this issue is to DQ or even fine any racer that has parts fall off his car during an event. Which would you prefer?
Header bolts are notorious for vibrating loose for obvious reasons. My collectors are welded, but when bolts are used they should be used with locking type nuts. Most aren't.
That is exactly what NHRA should do instead of forcing every racer to spend money because some do not check there stuff or use the correct hardware. I am under my car after 40 runs checking for loose bolts, etc. I have replaced grade 5 collector bolts many times because the threads look bad from overtightening. I switched to grade 8 bolts, lockwashers and crimped locknuts.
bert powell is offline   Reply With Quote
