Old 01-28-2013, 11:53 AM   #1
acme383
Default stick shift piston to head clearance?
Is .040 ok or should i put a thicker head gasket on it. zero deck motor.
acme383 is offline   Reply With Quote
Old 01-28-2013, 12:01 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 507 Times in 116 Posts
Default Re: stick shift piston to head clearance?
Type of engine? Piston to wall clearance? Class?
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 01-28-2013, 04:28 PM   #3
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Piston weight ?
RPM ?
Stroke length ?
Steel or aluminum rod ?
With 720 gram bare piston, I run .036" , to 7400... no issue.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 01-28-2013, 06:33 PM   #4
mtkawboy
Liked 54 Times in 18 Posts
We ran .050 on a 68 Camaro Z/28 stocker back in the early 80s. Those were the stock piston rule days. We wouldnt have if we could have cut the valve reliefs
mtkawboy is offline   Reply With Quote
Old 01-29-2013, 11:57 AM   #5
randy wilson
Liked 22 Times in 22 Posts
Plenty with steel rods, no matter the rpm.
don,t have one
Old 01-29-2013, 12:00 PM   #6
acme383
I don't have all the specs,but it's a 540 mopar with 4.500 bore and 4.250 stroke and uses a 7.100 steel oliver i-beam that i spin to almost 8000 rpm.
Old 01-29-2013, 01:48 PM   #7
Rory McNeil
Liked 1,104 Times in 302 Posts
Since this is obviously not a Stocker engine, why not cut deeper eyebrows for piece of mind?
NHRA 6390 STK
M/S 85 Mustang
Old 01-29-2013, 04:32 PM   #8
acme383
piston to head.
Old 01-29-2013, 05:14 PM   #9
randy wilson
40 is fine. For piston to head, that is.
don,t have one
Old 01-29-2013, 05:27 PM   #10
mtkawboy
Sorry, I misread it too. We ran .035, I wouldnt run less then .030 but some do
