#31 |
My 2 cents,
If you have a big-tired car, chances are you don't need counterweight on your clutch. Counterweight is great for a small tired, high hp car with limited traction. Low base pressure gets you off the starting line, counterweight locks it up at the gear change. If you use the clutch at the gear change, you'll need more pressure to lock the clutch back up, and that usually means the tires will chirp at each gear change. I usually start with all fresh pieces and turn up the static around 1000lb. Make a run and start backing down the pressure until it slips, then add 1/2 turn. Watch the tack on the starting line. When you let the clutch out, the rpms should not drop then rise. they should load the engine and then rise. Should shift smoothly at each gear change. If it slips into high gear, add counterweight. On a cool day you may need slightly more pressure. Hot days, it may be too aggresive. This is where you need to know your car. The clutch makes or breaks these cars... If you have a bearing problem, I suggest checking the bellhousing alignment. If its right, you should have no problem. _____________________________________ Andy Stone 1102 A/S 1112 SS/C |
#32 | |
Jeff Lee 7494 D/S '70 AMX |
#33 | |
Liked 13 Times in 11 Posts
I pull out some base in the interest of better 60fts or preventing breakage.......I offset that with c'weight. What exactly are you saying? |
#34 |
Guest
Posts: n/a
What he is saying, is when you have a light car with an unlimited tire size it shoud always hook. Run the clutch tight, leave on the valvesspring and it doesn't matter. When you run a car with a bunch of power and limited tire, it becomes a game of finesse. Soft base, extra counter weight lower starting line rpm. Leave at a lower rpm and the clutch will act soft, shift higher and the counter weight locks it up.
#35 |
Rob Youngblood has a big tire and he uses CW. And so do the SS/AH cars that run (very fast) with his clutches. The CW is there to adjust the slippage on the shift.
#36 |
#37 |
Liked 22 Times in 22 Posts
Not trying to steal the thread, but this has come up a few times here. To align the bell housing properly, get the browel tool, (which I now have), or, a simple method I used to keep pilot shaft bearings in that worked for me goes like this, put your clutch and flywheel in,( not in that order, Ha), set your bellhousing on, with dowels removed, start a few bolts, get a pilot shaft out of the transmission you use, slip a spare collar over it, slide it in through the clutch, let the collar go into the housing, wiggle it a little to make sure it's in the bushing, look at where your dowels go, and you will see what offset dowel you need, leaving it like that, drive the dowels in, make sure you can still slide the shaft, and collar in and out freely, start to tighten bolts, and wala, it works good. Beats the hell out of a dial indicator for me.
don,t have one |
#38 | |
Liked 520 Times in 132 Posts
#39 |
It all depends on the stagg rpm...lol
Sean Fischer ![]() Last edited by SuperStockDodge; 01-18-2013 at 09:33 PM. |
#40 |
Liked 112 Times in 31 Posts
For those of you wondering, heres a link written by fellow stocker racer Jerrry MacNeish.
http://www.camaros.org/bellhousings.shtml Jerry |
