Old 01-14-2013, 09:58 PM   #1
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Stock class racing seats
Originally Posted by Jim Kaekel View Post
You would be better off in the long run with an aluminum seat. The plastic seats have molded-in threads that can pull-out over time. A friend has one of those in a bracket car and after two years, the threads are already starting to pull-out of the seat, and he's not a real heavy fellow either. My .02.
x-s2 on the aluminum seats. leave the poly seats to the grade school cafeteria's
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 01-15-2013, 02:13 AM   #2
Phillip marvetz
Phillip marvetz's Avatar
Talking Re: Stock class racing seats
Chad should be here any second to scold you.
2009 V/SA Record Holder
Old 01-18-2013, 09:40 AM   #3
Chad Rhodes
poly seats belong in dune buggies ( or Phillip's car). As much as I disliked being required to run seats that in some cases are over 50 years old, installing a plastic one with molded in "inserts" seems even worse. There Phillip, are you happy now. Wasn't even going to reply till i read your reply.
Chad Rhodes 2113 I/SA
Old 01-18-2013, 11:42 AM   #4
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
I will keep my bench.....
Bob Bender 144 O/SA
Old 01-18-2013, 12:38 PM   #5
Liked 5,134 Times in 1,958 Posts
You daredevil, you
Old 01-18-2013, 07:40 PM   #6
SuperStockDodge
SuperStockDodge's Avatar
Thumbs up Bob!!!
Sean Fischer 5864 SS/E
SuperStockDodge is offline   Reply With Quote
Old 01-20-2013, 11:28 AM   #7
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
my question is, does this rule mean we can use a 4dr seat in a 2dr?
Old 01-20-2013, 12:09 PM   #8
Run to Rund
Liked 54 Times in 27 Posts
Not unless the rule changed recently.
