#51 | |
Liked 4 Times in 4 Posts
Rather than cutting into the overall purse maybe we could have a Gambler's race, winner takes all? JimR
Jim Rountree |
#52 | |
Michael, The tracks you mentioned are a little far away for Southern and probably some East Coast racers, can you look at someplace a little farther South and East...KY,TN,VA,WV, etc. Heck, I'd even travel to Atco just to see the place where it all started for me. JimR
Jim Rountree |
#53 |
Liked 77 Times in 15 Posts
I never mentioned dividing the purse. I suggested a third race, in addition to class and the eliminator. Call it a gamblers, combo, or whatever you want, to run the same day if there is a test day.
We run one on Sat. the day before the Lee Sherman race at MD with/after the test and tune, and it does not take any money from the guaranteed purse for the LS race on Sunday. Put up $50 per racer and run for the money. Mike B's response makes perfect sense to me, the number of anticipated racers would not cover his costs for another days rental for even earlier parking for the event. You can't expect a promoter to take a days loss for our enjoyment, our fun is someone else's business. My suggestion was, if there is a test and tune, schedule and run a combo race for the same day and track rental if possible. IT could be racer's entry is the pot or entry plus $5-10 to cover the costs. |
#54 |
Mike:
National Trails would be a good place because it is centrally located so, it will draw cars from a wider area of the country. Norwalk would be a nice place but would probably be hard to sqeeze in an event at an acceptable date for everyone. Good Luck it's a great idea and a huge undertaking.
Nelson Kowal Stock 345 |
#55 |
Liked 13 Times in 9 Posts
Lots of support from racers here at the IMIS show, and Redman's on board for the starting line!
#56 |
Liked 136 Times in 49 Posts
Just thought I would try and help out with a map so when people are deciding what is centrally located they can see the whole country.
#57 |
Liked 595 Times in 136 Posts
I meant to comment when the thread started but somehow it slipped off my radar.
I've been to a bunch of tracks across the country, and there are a very few where you instantly feel the difference between the operations of simply a promoter and someone who loves racing. Earlville is the most racer friendly track in the country as far as I'm concerned. No Problem is right there but I haven't been to the track since the management change, plus it's not nearly as central. In my experience promoting events many years ago, I'm acutely aware the entire thing involves juggling a bunch of pros and cons. Earlville might be more distant for a lot of racers than Columbus and without entrants there's no reason for the race. But then I think of the downhill staging, all-concrete track, racer barbecues, tree-lined pits, RV park. and the staff in the tower enjoying the action as much as the racers - and I keep coming back to Earlville. You can't get much more central than Gateway, but I can't see the event there for a lot of reasons. Yes, you could physically do it, but I'd bet a whole lot more racers would have smiles on their faces Sunday night if you held the event in Iowa. So even if you're juggling variables I think it's a mistake to base the decision because of an over emphasis on one of them. Whatever you decide to do, good luck. I think it's a tremendous idea. |
#58 |
Michael, having Redman is a HUGE plus. At the original Class Nat'ls in 2001, when it was 101 degrees, he kept the track HOOKING all three days. Would be great also to have one or two qualified, respected tech officials, also like the first Class Nat'ls.
Meant ot write some stuff earliuer this week, but was busy with dad's surgeries for cancer. Now that he is home and doing well, I can. I always said that trying to copy the original Class Nat'ls format would be perfect (since it was, then or since, the greatest event EVER for Class Racing cars, outside of Indy or the good old days at Bowling Green, G-ville, etc). However, I understand that getting a track for three to four days might be cost prohibitive). Using a three day format (just a few ideas) : ~Track operated test and tune with some type of Gambler (seperate S and S/S) or a Combo race, with x-amount payback, depending on how much the promoter, track, or both, are looking to make off of it. If not, just use it for parking and tech. ~two Qualifying Runs and Class Eliminations on Saturday; if there was time after to do it, and had sponsor money to do it, maybe a CIC-style race or something similar. ~Eliminations on Sunday. A central location, near a great number of cars would be good. Probably somewhere in Division 3 (Ohio/Indiana). Using Columbus as an example, you're about 550 miles or so from NJ, and less than 500 miles from St Louis; not far from the Michigan/Canada crowd, or the northern Div 2 crowd. A good area to draw from. Every so often, a Class nationals-type discussion comes up, and when people suggest places to hold it, many use a track(s) that are two hours or less for THEM. You need to have a location that better suits a LOT of cars, not just the select few who want a race like this, but only if it's in their own backyard. You can;t be that narrow minded. Byron IL was 500 miles for us, and we went to spectate (and gave up racing my street car in brackets at the IHRA race at my home track 25 miles away; didn't have a Stocker yet) because I wanted to be there to help support it in any way I could. And yes, no matter where you have a race like this, people won't go, for whatever reason (I've seen it first hand every year since 1999). The best location to have it is to have it at/near somewhere that can draw the most cars possible, which, again, would be somewhere in central Division 3. Michael, I'm in tohelp in any way I can. You know how to get ahold of me.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
#59 |
Liked 282 Times in 103 Posts
I don't know if it is actually a fact,but when I stayed at a Hotel in Columbus,Ohio in September,there was a sign on the wall that said; "Welcome to Columbus,Ohio,where 50% of the population of the United States live within 500 miles."
Last edited by 442OLDS; 12-08-2012 at 02:58 PM. Reason: Hotel was SLIGHTLY East of Columbus |
#60 |
Liked 174 Times in 39 Posts
http://en.wikipedia.org/wiki/Mean_ce...tes_population
The center of the country based on population is in south-central Missouri. It would be interesting to know the population center for racers, I wonder how much it would change.
3207 D/SA, C/ED |
