#11 |
Thanks Mike so if I understand correctly you are saying I will/should be safe with the normal Treemaster and dont have to spend the extra $100 for the MRT.
#12 |
Liked 1,967 Times in 595 Posts
Yes Eric you will have excellent results with the treemaster. I use the same type converter in my 1968 camaro super stock car. 6200 stall 3800 leave RPM 3200 lbs 350 cubic inch flat top motor w/ Q- jet carb 9.92 @ 129 mph
Mike Pearson 2485 SS |
#13 |
Man thats impressive what cam specs are you running and gear?? What kind of 60's are you pulling?
#14 |
Thanks Eric,
cam spec 276 @.050 .801 lift 105C/L install @99, Powerglide w/ 1.94 low, 6.17 rear, 12.5 X 31.25 M/T radial tires 100.5 roll out. This aint your dads bracket car. LOL Mike
#15 |
Went with a Coan 8 inch Art @ Coan told me to go with a 45-4800 8 inch so thats what we did, hopefully it will help me out!! Thanks for all your input!
#16 |
Good choice Eric. Let me know how it works for you. I use some of Coan's parts in my trans also, Brake , pump and light weight drum. E-mail me at ssia2485@yahoo.com
Mike
#17 | |
Hide and watch your 60' to 330' incrementals go crazy. 8" OPEL style front cover, minimum 5300 stall, all my problems went away. But I do everything wrong, I also ran 4.11 gears with a 1.76 Pukeglitch...... I'll NEVER part with my JOHN KILGORE 2.10/1.40 gear set in my TH-400........had it for 8 years now. |
#18 |
Whats up Goob-
Just so everyone knows the converter actually flashes to 5200, I asked him to make it lose (cause of what goob said) however, I took it to the track this weekend and ![]() Eric Bowling |
#19 |
oh ya almost forgot, it seems like I am not getting any body seperation anymore, also the front end is coming up and hitting where the Rubber Snubber USED TO BE. Once it gets there is when it drops quick then unloads, hopefully that will help out with your advise too. thanks again!
#20 |
someone?? anyone?? HELP!!!
