Liked 900 Times in 191 Posts
Try a larger diameter front tire or let a little air out your front. This will give you a bigger bulge at the bottom of the front tire and allow you a little more time in the front beam before redlighting.
Bob Don 128 SS |
I usually run 33lbs in the front. What should I drop it to?
Letting air out of the rears make more difference in my lights than out of the front.
Ed Wright 4156 SS/JA |
Liked 880 Times in 311 Posts
Side view, too much rotation on the hit. Inconsistant for bracket style racing, great for max et over dead hook.
side view : better hook on the hit. like Ed said car going forward before the front end lifted out of the lights.. In the back the tire side wall has too much bulge. that is making sidewall "work" too hard. Notice how the tire kind of "wallows around after the initial hit. wheel width needs to be matched to the tire or I would get a stiffer sidewall tire with matching wheel size. Then when the front end comes down you have massive toe /bump steer. that slows the car down. I guess i could do it frame by frame and get a few more ideas of what is going on. Hope that helps.
Adger Smith (Former SS) |
#5 | |
Liked 332 Times in 180 Posts
28ish see what happens ----if it improves maybe down a 1/2 pound at a time until its consistent---otherwise go up a 1/2 pound from 28 keep playing with it---just do maybe 330 foot or less launches til ya get it right--- all yer concerned with is the launch no point running it a 1/8 or more
#7 | |
the reason I say 28 is going down a 1/2 or pound ya wont really know or notice if ya did the right thing---go down an extreme amount like the 28 ish see if it likes it---if it does then go up a 1/2 or down a 1/2 see waht happens---ya can always go back to the 33 setting---way too much front tire wobble when it sets down need to correct that scuffing off a lot of time there--rims do look narrow for the tire maybe try a narrower tire on those same rims ---borrow a set to try-might try to up the rear tire pressure a bit see if it likes it---see ya have license plates on it is this a street car too??? might have something to do with the suspension----lotsa things going on there---front wobble/tire spin/wrong size tire-rim combo hafta sort one thing at a time out---if you want consistency 10.50 or whatever keep doing whatever yer doing if it runs the number dont change it---if ya wanna improve yer performance and go quicker ya need to change some things---if it runs 10.50 all day and the 60 changes from 1.30 to 1.45 as long as yer in front and go 10.50 who cares---
#9 | |
http://s807.beta.photobucket.com/use...05671.mp4.html |
Liked 251 Times in 125 Posts
Make sure you're just barely rolling into the stage beam. You may be deeper than you think. It's sometimes hard to tell from inside the car just how far you're in. A helper on the line can give you an idea of how far you're rolling in, compared to how far you THINK you're in.
