Old 10-03-2012, 04:20 PM   #1
FINESPLINE
FINESPLINE's Avatar
Default Re: Shubeck style lifters
S mith Machine was making the Schubeck style lifters the last time I heard. My 2 cents about them is there are better ( safer ) ways to go.
FINESPLINE is offline   Reply With Quote
Old 10-04-2012, 04:00 AM   #2
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Exclamation Re: Shubeck style lifters
I recently broke two smith lifters on my new engine after about 9 runs. All I can tell you is I broke the last Smith lifter I will ever brake! It could have been worst and I could have lost the entire engine. A new set of pistons, cam and tool steel lifters and the problem will be solved. The funny thing is my spare engine has Shubeck lifters and they have never failed. Simply put, no one can afford to destroy their engine with defective lifters! It only took one lifter failure to realize we have a weak link.
Anyone who is building a new engine should investigate tool steel lifters. They will not come apart and cause extensive internal engine damage. Hopefully, the people at Smith lifters can find the reason why their product is failing and correct the problem.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 10-04-2012, 08:50 AM   #3
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Shubeck style lifters
Who makes the tool steel lifters? I've heard about them and don't have a recommended brand name. Will they work with that steel cam I have?
Old 10-04-2012, 11:36 AM   #4
Tom Moock
Liked 10 Times in 6 Posts
Greg, Cliff Sherman makes tool steel lifters that are shimmed up to allow .012 in. of plunge. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 10-04-2012, 12:02 PM   #5
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Cliff Sherman's contact info???
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-04-2012, 01:02 PM   #6
Jeff Lee
Jeff Lee's Avatar
Tool steel lifters set up for NHRA / IHRA are available here:
http://www.precisionenginetech.com/p...solid-lifters/
Jeff Lee 7494 D/S '70 AMX
Old 10-04-2012, 01:31 PM   #7
njk53
Are these lifters legal with a hydraulic camshaft, like the Schubecks? Their webpage says solid lifter.
Nelson Kowal
Stock 345
Old 10-04-2012, 04:00 PM   #8
FINESPLINE
FINESPLINE's Avatar
Greg, Trend and PPPC are a start. Depending on the pressure over the nose of the cam you can get recommendations. I just recently read on another forum concerning these lifters. Mike Jones (camking) of Jones cams can point you in the right direction. Ferrea also markets a tool steel lifter. Depending on your core there are DLC and nitride coatings.
