Old 09-24-2012, 05:35 AM   #11
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: fuel line question
Originally Posted by David Lee View Post
Jim can you tell me what you used? I am ready to run from the fuel cell up the regulator
i'd like to know,too.
that's the kinda stuff i was looking at but i don't know anybody that's used it
Old 09-24-2012, 08:08 AM   #12
Billy Nees
Liked 7,925 Times in 1,760 Posts
Tom, use Moroso aluminium line.
Billy Nees 1188 STK, SS
Old 09-24-2012, 10:48 AM   #13
Signman
Liked 269 Times in 99 Posts
Have aluminum line in both of my cars.
Earls makes aluminum line that can handle higher pressure.
Carefully route it and support it well with rubber covered P-Clips.
Terminate it correctly.
Slip heat reflective cover over it.
Will last a long time especially if the floor does not have a lot of flex.
The ID of the 1/2 inch aluminum tubing is larger than that of the generic AN-8.
My .02
Old 09-24-2012, 11:41 AM   #14
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Talking Re: fuel line question
Now you do Tom! I've seen several Stockers with it. In a full cage car I think the solid lines are fine but I would think in a Stocker or a car with some flex in it braided steel or the new braided nylon would be smarter. I ran the Moroso aluminum line in my SS car for many years with no problems. Just my opinion. Jim
Old 09-24-2012, 11:54 AM   #15
Jim Wahl
Jim Wahl's Avatar
Wink Re: fuel line question
I don't want to change the subject here but someone brought up the Holley Blue pumps. I ran two of them back in the day on my SS car for years with no problems. When I got the Volare' it had a Holley Blue pump on it and at the first race it seized up and I put a new one on it which started leaking at the second race I went to. I replaced that one with another and it started leaking two races later. I since have replaced the Holley with an Aeromotive pump that, other than being very loud, has been flawless. I have run over 118 at "H" weight several times with it so I think it is providing plenty of fuel. I have a MagnaFuel pump waiting just in case. My point with this is that the good 'ol Holley pump "ain't what it used to be" in my opinion. Once again, just my experience and opinion! Jim
Old 09-24-2012, 04:36 PM   #16
Stock726
Liked 39 Times in 10 Posts
Agree with that. Holley quality control is not as good as it used to be.
Heck, Bary Grant used to make good components back in the day; now it's just junk. Don't you just love outsourcing???
Stock726 is offline   Reply With Quote
Old 09-24-2012, 07:08 PM   #17
Tom keedle
Tom keedle's Avatar
i'll be running K,L, or M /stick and i was looking at the braided nylon but as there's so many different mfgrs, who's do i use and who's do i stay away from?
Old 09-24-2012, 08:24 PM   #18
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Tom just go down to the nearest AMC dealer and order the factory line.That'll do it.
Ed
Former NHRA #1945
Former IHRA #1945
T/SA
Old 09-24-2012, 08:40 PM   #19
Tom keedle
Tom keedle's Avatar
Ed
i did but they're backordered...
Old 09-24-2012, 09:31 PM   #20
Jim Wahl
Jim Wahl's Avatar
Exclamation Re: fuel line question
Tom, here is the NHRA accepted list. As you can see both Jegs and Summit have accepted lines.
Highlighted items designate recently added since last revision
Manufacturer
Hose Description
Notes
Aeroquip
FC300
Black heavy hydraulic
Aeroquip
FC332
Blue
Aeroquip
FC598
Same as F332 but black
Aeroquip
Star Lite 200
AQP
Socketless
BMRS
Polyester Braid
BMRS
HTP Braid
Dayco Imperial
Nelo-Seal Tubing
Earls
Pro-Lite 350
Earls
Super Stock
Earls
Ultra Flex 650
Earls
Diamond Lite
Fragola Performance System
Series 8000 Push Lite
Pro Crimp I
Series 8600 Parker Push Lock
Gates
LOL Plus
Goodridge
536
Goodridge
710
Goodridge
910
Russell (Parker)
Pro Classic
Russell (Parker)
Twist Lock
XRP
XR-31
XRP
HS-79
XRP
Push On
Blue or black
Jegs
Pro Flow 350
Summit Racing
Twist Tite
Precision Performance
Flex Loc
