Liked 346 Times in 126 Posts
Jim can you tell me what you used? I am ready to run from the fuel cell up the regulator
Liked 2 Times in 2 Posts
I re-plumbed my car early this year.I used steel line and bent it myself.I used it from the pump to the regulator,then used push lok hose from regulator to carb.
The steel line I got a great deal on Ebay,a 25 ft coil.
Nautilus Racing |
Liked 5 Times in 3 Posts
The "twist-loc" rubber line is very easy to use! Put hose in pan of boiling water & push AN fitting on the line..your done!
#4 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
I`ve had good service with the aluminum Moroso 1/2" fuel tubing. I still have the same tubing in my bracket car that I installed back in 1987, never had a problem with it. I did secure it with rubber lined Adel clamps every 10-12 inches. Its lightweight, cheap, easy to bend, and your fingers won`t bleed like they do with the braided stainless steel stuff. As for plumbing the pumps, a return system may be considered "better", but both my bracket car and my Stocker use "deadhead" (non return) Holley blue pumps, the pump in the Stocker has been in for 10 years, the bracket car 25 years(!), and they are still working fine.
#6 | |
Liked 8 Times in 7 Posts
that's the kinda stuff i was looking at but i don't know anybody that's used it
without losers,winning means nothing. |
Liked 7,925 Times in 1,760 Posts
Tom, use Moroso aluminium line.
Liked 269 Times in 99 Posts
Have aluminum line in both of my cars.
Earls makes aluminum line that can handle higher pressure. Carefully route it and support it well with rubber covered P-Clips. Terminate it correctly. Slip heat reflective cover over it. Will last a long time especially if the floor does not have a lot of flex. The ID of the 1/2 inch aluminum tubing is larger than that of the generic AN-8. My .02
#9 | |
I don't want to change the subject here but someone brought up the Holley Blue pumps. I ran two of them back in the day on my SS car for years with no problems. When I got the Volare' it had a Holley Blue pump on it and at the first race it seized up and I put a new one on it which started leaking at the second race I went to. I replaced that one with another and it started leaking two races later. I since have replaced the Holley with an Aeromotive pump that, other than being very loud, has been flawless. I have run over 118 at "H" weight several times with it so I think it is providing plenty of fuel. I have a MagnaFuel pump waiting just in case. My point with this is that the good 'ol Holley pump "ain't what it used to be" in my opinion. Once again, just my experience and opinion! Jim
