Old 09-13-2012, 10:14 PM   #21
nolongerracing
Liked 72 Times in 27 Posts
Default Re: 305 Stocker Block Question
You are missing my point....NHRA doesn't care if you put 4 bolt caps on a 305. They don't care if you cross bolt a 428 or 390 FE or 440 Chrysler. They don't care. Thats why they approved all the aftermarket blocks.
Originally Posted by Dean Feiock View Post
I don't use a 305 block. As I stated, I use a 307 or 350 block.
All the things I do to my blocks (block true, lifter true, align hone, etc), need to be done to a new Dart block as well. If you have never used one you should note that they don't come finished.
The fact that Dart is not making a "small bore block" means you will need to install sleeves, just like we do in 307 & 350 blocks. The only difference is that we start with, as you put it, a $50 block instead of a $2000 block. The required prep work is the same.
nolongerracing is offline   Reply With Quote
