Old 09-11-2012, 03:45 PM   #8
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: Quadrajet Gasket and tuning
For the gaskets your allowed two, we run the 4 hole on the bottom open on the top(worth some torque). I would test the flow on the pump it should overflow a gallon container in 30 sec. through the reg. at 7psi. If that checks ok check the sec. side of the carb, how do the plugs look after a pass. X2 on giving Danny a call. gsa612
