Thanks Bill for the info, very helpful now if I can just get time to install it.
Coot,
Have you thought about installing a pcv valve on both sides. We were doing that with Stocker motors a few years ago. |
We run regular seals and pull 12-15" of vacuum with no problem.
Bill Huntington S/C, S/G, T/D, S/Pro |
Liked 100 Times in 51 Posts
I run about 14.2" at the finish line. I run the crank seal in the normal direction. No leaks, no issues. As stated earlier, the vac pump will help cure most oil drips and oozings.
