View Poll Results: Which Ford Stocker seems the best choice?
1960 Custom 4dr, 300hp 352 (12.02) 7 58.33%
1978 T-Bird, 400 (17.00) 4 33.33%
1979 LTD 2dr, 302 (21.02) 1 8.33%
Voters: 12. You may not vote on this poll
Old 07-16-2012, 11:48 AM   #7
goinbroke2
Liked 393 Times in 153 Posts
Default Re: BIG Ford Combos?
400 2bbl has low compression and huge piston tops....but...I think they have a lot of potential. Still, I think the 351M would be better than the 400 for the same reason a 302 is better than a 351W, same breathing (carb/heads) with smaller cubes.
2.05int and 1.72ex valves plus big ports in intake, the only issue is carb cfm which I think is 350cfm if I remember right. As long as you modify the oiling system (restrictors in the cam feeds) I think it would stay together. Of course the availability of aftermarket pistons/rods is a pain, but you know it won't spin up past 6000 so who cares?
Not a record holder but I think it would beat the index.
351 crank and pistons....now you've got a 351M instead of a 400.......
