Old 07-07-2012, 09:16 PM   #1
Capri
Liked 27 Times in 14 Posts
Default Re: Ford 390 FE help
Robbie,
If we can help let us know.
monymkrssla@aol.com
In case you have to change cams n lifters.
Tony
Capri is offline   Reply With Quote
Old 07-08-2012, 12:03 PM   #2
Robbie Welch
Liked 262 Times in 124 Posts
Thanks Tony, I think I've got it now. Not sure why the balancer/pointer where off 8degs (balancer problem?) but I redrilled the mounting holes for the pointer and its good now. How's your dad doing? Robbie
Old 07-08-2012, 12:16 PM   #3
Capri
I suspect the balancer is off. We have used a timing tape to fix that on ocassion. They are not expensive an we keep em on the shelf. Sometimes balanacers are mis marked, and others the pointer is tweaked.
Dad is doing pretty decent all things considered. Now its all about the therapy.
Old 07-08-2012, 04:27 PM   #4
BlueOval Ralph
Banned
If it is a stock Ford unit it very common for the outer ring to slip, there is a very good company called Damper Dudes in Calif that rebuilds stock units.
BlueOval Ralph is offline   Reply With Quote
