Old 07-01-2012, 09:27 PM   #11
james schaechter
Default Re: Deconstructing Stock
I think it is time to consider GT stock. Similar to the SS concept only no FWD conversion cars. Imagine if you could run an older body style and a newer engine type. Maybe you want a new CJ DP or Camaro. Just can't cut the check for $$$. Do the engine R and D in the older car while you build your own. Your old car is worth something on the market and you can take some time building the new one. This way you don't have to be a rich racer or remortgage your soul to play with the new engines.
Also, there are tons of street rods doing this already. Fans would understand this. Ihave seen Camaros, Novas and chevelles with LS engines in them for example.
James Schaechter 3163 STK
