Old 06-24-2012, 01:44 PM   #5
Dave Casey
Liked 769 Times in 162 Posts
Default Re: jerico input shaft sensor
Search here in the tech section and you will find it i believe, you don't need the 1:1 if your data system can apply a ratio to the graph, which some can I am told. just apply the head set ratio and put the sensor on the counter shaft. The problem is that the bellhousings in stock are not as deep as let say pro stock and they can get the sensor in there easily. Last I knew they used sensors on the input in pro stock,
Dave Casey 1330 STK
