Old 06-14-2012, 05:14 PM   #32
Vic Santos
Vic Santos's Avatar
Liked 14 Times in 2 Posts
Default Re: Help!! Engine Miss
Ben, I've been anxiously waiting for the solution to be posted (it hasn't yet). It made me go back to your original posting. You said you changed switches and added a ground terminal because your old switches didn't need a ground. Unless your all your circuits were changed to relays (and your switches switch to gound to turn on the relay) your switches should not need a ground. Most switches have a 12v supply and switch the 12v to the component that needs it and the component is grounded. I'm confused why a switch would need a ground.
Vic Santos
Vic Santos is offline   Reply With Quote
