Old 05-23-2012, 01:02 PM   #21
tim worner
Liked 126 Times in 20 Posts
Default Re: gauge of wire for Alternator to battery?
#4 or 6 welding cable works very well
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 05-23-2012, 09:07 PM   #22
magnumv8
Unless I missed it you do not have to run the alternator charge wire to the rear where the battery is....you already have a battery cable large enough to operate the starter in the car so all you need is a cable of enough capacity to go from the alternator to the junction point of this cable (starter solenoid)...that is why you don't need a real large wire from the alternator to this point (short run)......also the charge signal from the alternator can be very a "dirty" signal (not real clean) and this can cause all kinds of RF in the car if not handled well......
D L Rambo.....
magnumv8 is offline   Reply With Quote
