Old 05-22-2012, 07:13 PM   #1
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Default Re: Clutch switch
It's not that bad Ed, once you get used to it..You just use a little finesse..
I haven't started a stick shift race car in gear ,in about 40 years..
Once you have thrust bearing issues , you won't either.
I've never had a thrust bearing problem in the 40+ years I've had my car. Not saying it can't happen just I haven't seen it. I never trust the fact the trans is actually in neutral even if I put it there so I'll continue to start the car with my clutch pedal down. Maybe that's because of the freezer in my parent's garage I drove into as a kid!
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 05-22-2012, 07:54 PM   #2
Ed Wright
Ed Wright's Avatar
I never had a thrust bearing problem either. No soft clutches back then either. Always started them in gear, clutch down. Maybe I was just lucky?
Ed Wright 4156 SS/JA
Old 05-22-2012, 09:01 PM   #3
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Me neither, Ed... that's why I take my time putting the transmission into gear.
About this thrust bearing concern...
The only time I ever saw a thrust bearing worn for no apparent reason, was a factory 454 in front of a TH400. I've been told that these transmissions have a somewhat high internal pressure, particularily in reverse... causing the converter to push forward with substantial force.
I dunno
that's as close as I'll get to an automatic
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
