Old 05-16-2012, 08:42 PM   #1
2percenter
Default gauge of wire for Alternator to battery?
What gauge wire would you guys use for a 1 wire 140 amp alternator lead to the battery positive side mounted at the rear of the car?
Is #10 gauge alright?
2percenter is offline   Reply With Quote
Old 05-16-2012, 09:15 PM   #2
pmrphil
Liked 348 Times in 152 Posts
Default Re: gauge of wire for Alternator to battery?
I believe that #10 wire will only carry 30 amps, can't imagine 140 going thru that small of a wire - maybe a #6 is enough? I would think that should be a lot closer.
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 05-16-2012, 09:42 PM   #3
Liked 1,826 Times in 414 Posts
Six or eight gauge, minimum.
Old 05-16-2012, 10:18 PM   #4
Chad Rhodes
I've got a #6 but my battery is in the front
Chad Rhodes 2113 I/SA
Old 05-17-2012, 01:04 PM   #5
Run to Rund
Liked 54 Times in 27 Posts
20' long wire for 140 amps would be 0 gauge. See the table in this thread on yellowbullet:
http://www.yellowbullet.com/forum/sh...ad.php?t=47266
Old 05-17-2012, 02:32 PM   #6
2percenter
Okay, so 6 or 8 gauge it is. I was lead to believe that 10 gauge was enough for the field stud from the alternator to the battery. Yes, the battery is in the trunk.
What type of wire is good? crosslink? solid strand?
Old 05-17-2012, 02:49 PM   #7
Harry 6674
Use copper stranded that is designed for automotive use. It's more flexible then equipment wire.
Harry 6674 is offline   Reply With Quote
Old 05-17-2012, 08:37 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Be sure to use a fusible link or a maxi fuse on each end when using heavy gauge wire for the alternator. , you dont want to burn the car down if the wire gets pinched !
Old 05-17-2012, 09:03 PM   #9
68camaroSS
I did a little research on this last year and ended up using 6 AWG fine stranded tinned marine battery cable boat wire on my 90 amp alternater, bought on ebay for 1.25 a foot.
68camaroSS is offline   Reply With Quote
Old 05-17-2012, 10:41 PM   #10
2percenter
Funny thing is that I have been using #10 gauge on this connection for some time now with no problems, but I guess I got lucky with that one.
Could the car have not been getting full amperage to the electric fuel pump and electric cooling fan under full load?
I'm going for #4 or #6 to make sure it's right.
