Liked 71 Times in 23 Posts
Change the front springs, they are cheap and easy. Then put the CO6 Hoosier 30/9 92.5 on it and run it,then start working on the chasis for your stock eliminator endeavor.
Start out with 20-22 lbs of PSI.
Monte Howard 3209 STK, 3208 SS Last edited by Monte Howard; 04-17-2012 at 07:00 PM. Reason: CO6 not CO7 |
#2 | |
thanks everyone for replies...
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Once you get it working good, go test and go up 2 psi at a time till it spins. You will pick up et From 22 psi on, I would not be surprised to see you end up running around 26 psi.
Monte Howard 3209 STK, 3208 SS |
