Old 04-05-2012, 05:01 PM   #1
Default Re: 1964 426-S 'Street-Wedge'
Almost as good as a little blue pill!
Old 01-17-2013, 02:23 AM   #2
Albert Lee
Liked 258 Times in 49 Posts
Paul,
The 426 Street Wedge represents a blend of BOTH the Old and New. The '64 motor is now rated at 291 Hp by NHRA and can run in Stock (F/SA thru J/SA with various weights and bodies) as well as the NMCA Nostalgia Super Stock classes with the exact same set-up. There are some superseded parts including 915 heads (with 1.60" exhaust valves), intake manifolds and even the new aluminum Edelbrock heads (with a 50# weight penalty). Of course the small carburetor and .431" lift cam still remain. Overall, it looks pretty good,
As an example, the Plymouth could run in H/SA on a 12.15 index with a minimum weight of 3515 pounds. I actually ran this combination a little bit (1/2 second under) last year but didn't like running in the 11's and shelved the project for the time being.
Times change but the 426 Street Wedge could be a neat and fairly inexpensive way to run races in TWO sanctioning bodies with ONE car!
Al Corda
Albert Lee is offline   Reply With Quote
Old 01-17-2013, 03:40 PM   #3
Paul Ceasrine
Liked 10 Times in 10 Posts
Al,
Did not know the NHRA dropped the 426-S (365 HP) all the way down to 291.
Always felt the 426-S was way overrated back in the day. But 291 HP....WOW !
One of our friend's ran a 64' Sport Fury in C/Stock in 1968..... It was a massacre.
Smartly switched transmissions to a 727 Torque-Flite, and moved over where C/SA was much easier.
Camshaft
Valve Train
Carburetor
Intake Manifold
Cylinder Heads
Compression
All needed help. Just like the 383's.
Old 01-17-2013, 06:30 PM   #4
Paul Ceasrine
Al,,,,,,,,
1971 U.S. Nationals
E/SA.........1964 Plymouth Station Wagon - 426 Max-Wedge
(9.00 - 9.49 Wt/Hp)
Old 01-17-2013, 08:06 PM   #5
akrondon
I've got everything to make a correct 426S for my '65 Belvedere. My thought up until reading thru this thread was to pull out the 440 in the next few years, throw in the 426S and run in the Pure Stock drags. Now, not sure I want to slow down to 13 second runs. Felt sure it could go high 12s with slicks, not so sure now.
akrondon is offline   Reply With Quote
