Old 03-19-2012, 02:07 PM   #1
Tom Goldman
Tom Goldman's Avatar
Liked 887 Times in 239 Posts
Default Re: looking for a source for alum. intake runners
I got some from Swartz Racing a few years ago for an AMC manifold I built .
I think CFE sells them also.
http://www.swartzracingmanifolds.com/runners/index.htm
OOPS ,Sorry I missed the no billet at the end.
Old 03-19-2012, 02:12 PM   #2
FED 387
Liked 335 Times in 182 Posts
Thanx Tom --looked at both Swartz and CFE--great stuff but too pricey to cut up and play with------keep thinking tho--FED387
Old 03-19-2012, 03:56 PM   #3
FINESPLINE
FINESPLINE's Avatar
Have you tried Weinle Motorsports in Ohio. The do tin manifolds but not sure billet or not. Worth a call !-------John
FINESPLINE is offline   Reply With Quote
Old 03-19-2012, 03:57 PM   #4
FED 387
Thumbs up Re: looking for a source for alum. intake runners
will check them out
Old 03-24-2012, 08:16 PM   #5
FED 387
Default Re: still looking for a source for alum. intake runners
still looking
Old 03-25-2012, 07:51 AM   #6
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
FED: dont know how crafty you are but, if you take square or round stock (dont know what ports you are working with) of the size ports needed ,you can form .080 5052 aluminum around that and make half sections ,find your taper that you need and weld them together ,, it's worth a try if you experimenting gmonde
Old 03-25-2012, 09:07 AM   #7
FED 387
Gmonde---thanx for the tip --no problem making them thought someone still did it the "old fashioned way"--somebody is still making these only need one or two ----not everyone is going the billet route at least not at this point--bout ready to hack up an old tunnelram just for the runners---when I get the correct dimensions I want gonna have a local guy fab them up FREE out of billet just need to make sure of my dimensions---thanx for the tip---FED387
