I just got a ford rear center section that has a stock 4.20 gear in it. It has 42-10 and a ford emblem stamped on the ring gear. I also counted the ring and pinion gears and they both were 42 and 10. I have never seen this ratio used or heard of this ratio also. Is their anyone that can help me with what and when this was used. Thank you for the help.
Banned
Could have been a NASCAR gear set the had a ton of oddball ratios. Ford made them at the Serling mi axle plant. There was a 4.29 ratio that was a standard gear set.
Wow, thank you for that information on the gear. I thought it was a odd ball gear size. I have looked all over the net and everyone that I talk to says it is a Nascar gear set.
Really doubt those gears were for CUP racing. They would be spinning about 11,000 RPM @ 200MPH
Banned
Just so you understand NASCAR some of the short tracks Bristol, Martinsville, Richmond use as much as a 6.20/6.50. A 4.20 could be used Darlington Rockingham Phoenix
Liked 20 Times in 12 Posts
I would recount that ring gear, nascar runs a 422&a 430 never heared of a 420.
Rich |
#7 | |
#8 | |
Liked 68 Times in 41 Posts
Google it "early bronco with a six cylinder. Don't know anything else, but I figured I'd let you know"
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
