Old 03-11-2012, 11:10 AM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Plastic or Aluminum fuel cell?
Most of the professionally built stock/super stock cars I have seen, as well the new factory race cars have aluminum fuel cells if that tells you anything.
That said, I wouldn't waste my $ or time putting a fuel cell in your stocker wagon, there is no performance advantage as I've made over 4000 passes in my '68 Chevelle with the factory unsumped gas tank, running as quick as 9.80's and 60 footing a best of 1.28.
Old 03-11-2012, 12:35 PM   #2
Phillip marvetz
Phillip marvetz's Avatar
I bought a aluminum 5 gallon cell and mounted it under the steel cover for the spare tire, You can cut a hole in the floor to drop the cell thru for clearance if needed.
My chevelle went 1.28 BLAHBLAHBLAH. Who cares?
2009 V/SA Record Holder
Old 03-11-2012, 12:40 PM   #3
72Malibu
72Malibu's Avatar
I had my car slip off jackstands, caving in the stock tank. I opted for a 15 gallon fuel cell, the empty cell weighs nothing or fill it up for added ballast.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 03-11-2012, 12:42 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Plastic or Aluminum fuel cell?
I've seen a lot of plastic tanks warp. Aluminum has to be better, looks nicer, easier to maintain and easier to keep track of how exactly much gas is in it. I use to have a 10 gal. aluminum cell but switched to a 5 gal. aluminum. It's plenty for several runs, but I throw a splash in after every pass anyway. Besides, no sense in having any more of what can go "BOOM" on board than you have to.
Old 03-11-2012, 05:27 PM   #5
Eric Kitzan
Eric Kitzan's Avatar
Did you do that in a stocker? I was told by Div 5 tech that the only hole I could cut was for the sump, and I had to make a cover for the fuel cell.
Eric Kitzan
66 Chevelle Malibu Wagon
Stocker
Eric Kitzan is offline   Reply With Quote
Old 03-12-2012, 12:44 PM   #6
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
thats funny right there!
figure out how much fuel you need for one run and double or triple it. that is all you need. why would you want to carry more fuel than two runs could possibly take. i don't think theres a stocker out there that runs on 2.5 gallons per run? if your fuel doesn't pass then you have to drain 5- 10 gallons, that not cool. removing the foam only works if you keep it topped up. i run a 1 gallon cell. my 350 uses 1/3 third of it per run if i have to idle behing a jr. on the return road. i have made three passes back to back to back without waiting inline or being slowed down on the return road - no fill ups. Aluminum looks nicer, plastic is lighter.
Ian
Ian Hill is offline   Reply With Quote
Old 03-11-2012, 12:58 PM   #7
Steve Hayward
Ed No doubt a stock tank will work in his car........ But this is not a bracket car... He will have to go through fuel checks........ It is much easier to manage fuel quality through a smaller amount....... Aluminum is very nice, but plastic will work........
Steve Hayward is offline   Reply With Quote
Old 03-11-2012, 02:38 PM   #8
1320racer
1320racer's Avatar
Steve, easier? If you say so but what did everyone do before fuel cells were allowed in stock the past decade?
Old 03-11-2012, 09:19 PM   #9
Steve Hayward
Not sure, but have you heard how finicky fuel checks are these days??? Managing a small amount of fuel must be much more cost effective.
Old 03-11-2012, 11:28 PM   #10
Phillip marvetz
Yes, Because it's a wagon you can put the cell below the floor.
