Old 02-22-2012, 04:05 PM   #21
JCChildress
JCChildress's Avatar
Liked 13 Times in 6 Posts
Default Re: SS Chevy II race weight
I respectfully disagree Ronnie. I wont use any of that stuff. It will just take time, creativity and enginuity. ( and a lot of grinding abd drilling........and chrome moly..) lol
JCChildress is offline   Reply With Quote
Old 02-22-2012, 10:32 PM   #22
Dan Jacobs
Ronnie you are correct. The list is long of things to do. Good Luck with grinder and Drill JC.
Dan Jacobs is offline   Reply With Quote
Old 02-22-2012, 10:52 PM   #23
Darrin Christen
Darrin Christen's Avatar
Does anyone know why the hardtops are heavier than the sedans, or is it just a myth?
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 02-22-2012, 11:10 PM   #24
Tom Meyer
Liked 354 Times in 120 Posts
The super sports are a different shiping weight than a reg ht. Shipping weight on post car is 2775, 2829 on a ht and 2868 on a ss. The factor on a ht is 11.99 or a j car the ss is 12.18 a k car so if you have a ss with a 283/236 you can still run SS/LA, a ht is K or J. I have done a lot of work but don,t think I can get close to j min. The post car is almost a 100 lb lite than ss. Tom
Tom Meyer 5240 SS Stock ???
Old 02-22-2012, 11:17 PM   #25
Darrin Christen
Tom, I understand what your saying, I would like to know what part of a hardtop makes it heavier than a sedan. Is it just because it has less options? I would think the sedan would be a little heavier than a regular ht because the sedan has the frame around the door windows, or maybe the door glass on a sedan is thinner than a ht because it has a frame to support it. I don't know, just something I always wondered about.
Old 02-23-2012, 12:32 AM   #26
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
My car does have a CM cage but it has a Dana 60 steel spool,gear isn't lightened, no gun drilled axles,single leaf springs still under it. How much lighter would it be if I went to a 9" with aluminum spool,lightened gear, gun drilled axles etc?
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 02-23-2012, 12:35 AM   #27
The hardtops have extra sheet metal bracing so the door openings remain consistent...Most noticeably ,a thicker galvanized strip inside the rocker panels.
BTW, The roof line is actually about an inch lower on the hardtops.
Old 02-23-2012, 12:37 AM   #28
Ed Carpenter
Originally Posted by Ronnie Smith Jr View Post
I believe it can be done - although you will not like the cost it takes to get it there.
lots of acid
aftermarket panels including quarters
aftermarket glass - all sides
aluminum where you can
titanium where you can
chromemoly throughout, round tube only, no retangular or square tube
this is just for starters - feel free to add to the list
Ronnie it's going to be interesting to see when mine is done from the total makeover this summer what it will weigh. I'm going to dip the doors,trunk lid,fenders and hood. All new glass as well(suppose to be lighter). I need 80 more lbs out of this car. How's yours coming?
Ed Carpenter
Old 02-23-2012, 12:55 AM   #29
Darrin Christen
Thanks Mark, Thats the kind of info I was looking for.
Old 02-23-2012, 07:43 AM   #30
danny waters sr
danny waters sr's Avatar
Lightbulb Re: SS Chevy II race weight
4-door is lighter than the 2-door hardtop.... Same weight as a 2-door post,,,,,,Now that don't figure to me....
