Old 02-12-2012, 07:04 PM   #1
eddie c
Default Full floating wrist pins
Wanting to build a street motor for a 1996 350 Chevy LT1 motor. What I
would like to know is what are your thoughts on making the wrist pins
full floating. I have always thought that by doing so that you reduce friction or drag on a rotating assembly. I know that alot of high performance factory motors use full floating set ups. Anyway has anyone
ever tested a motor before and after a full floating set up has been
installed and what results has it shown. I also would like to know your thoughts on which is more reliable full floating or single floating. THANKS ed
eddie c is offline   Reply With Quote
Old 02-12-2012, 07:15 PM   #2
Liked 1,912 Times in 429 Posts
Default Re: Full floating wrist pins
Full floating wrist pins are for ease of maintenance and disassembly, there is no performance gain.
With the correct retainers, full floating wrist pins are reliable. I rarely build an engine without full floating wrist pins, since I almost always use an aftermarket connecting rod and a premium piston. I prefer round wire locks, but spirolocks are fine.
